- CPU Fan Replacement Issue - No Display
- Laptop fan running but no display - Guide
- Cpu light blinking but no display ✓ - Hardware Forum
- Cpu fan spinning slow no display - CPU & Desktop Forum
- 5 beeps on startup no display ✓ - CPU & Desktop Forum
Ambucias
Monday February 1, 2010
11,176
Sep 5, 2017 at 04:51 AM
Hi Cath
If you have placed the CPU FAN without removing the old thermal compound and
applying a new one on the processor then remove the old thermal compound
from the processor and make sure that your CPU FAN is also clean without any
thermal compound.
Now freshly apply some thermal compound in the middle of processor and
fix the CPU FAN properly.
Good Luck.
thermal compound.
Good Luck.
Hi Ambucias,
Thank you for the suggestion. I was concerned about the thermal paste but some other forums where saying that with my model of laptop it wouldnt be a huge issue because the screws hold it down in place. Is this the wrong advice? Would something like thermal compound ruin the display? Everything else is running fine and the computer isn't overheating. Simply the display isn't working - it works on an external display.
Thank you for your reply.
Ambucias
11,176
Sep 7, 2017 at 05:30 AM
Sorry Kath but I have given you all the help I could considering the knowledge I have.
Matabaseng
Ambucias
Sep 7, 2017 at 06:51 PM
Thank you for the help you gave. Kath
