No display to my monitor, no power to mouse and ke
Briandug
Tuesday March 6, 2018
Mar 6, 2018 at 06:26 PM
Blocked Profile - Mar 7, 2018 at 03:43 PM
- No display to my monitor, no power to mouse and ke
- 5 beeps on startup no display ✓ - CPU & Desktop Forum
- Sceptre monitor no signal entering power save mode ✓ - Hardware Forum
- 3 beeps on startup no display ✓ - CPU & Desktop Forum
- Why is my mouse off center - Guide
OK, so you replaced the motherboard....how much did that cost? Did you use thermal paste when you placed the CPU? What about ESD strap, did you use it? Have you tried a new Power supply. I wold have swapped that out first, as it is a $20 item, and more than likely the cause, especially since you say the new EQ is doing the same thing. The PSU is bad!
