Very strange wifi speed issue
rodrigofs.fs Posts 1 Registration date Friday December 28, 2018 Status Member Last seen December 28, 2018 - Dec 28, 2018 at 11:28 AM
 Blocked Profile - Dec 28, 2018 at 01:02 PM
I have no idea of what's happening with my wiFi connection, so any ideas will be very appreciated.
I'm using a tp-link TL-WN725N adapter on a windows 10 PC, and I currently have a 150Mbps internet link.
The problem goes as follows:
Using 2g wifi (the only one supported by my adapter), I can reach ~50Mbps (speedtest.net) on any connected device (samsung galaxy s7, macbook, asus eeePc), however, on this PC using this adapter, the maximum speed is only ~1Mbps. I first thought it was an adapter problem, however this is when things get strange: using my samsung s7 connected to 2g wifi network, I can route the connection, and then, connecting the adapter to my cellphone, I can reach the same ~50Mbps on my PC. Very weird.
2.4g wifi -> PC = ~1Mbps
2.4g wifi -> galaxy S7 -> PC = ~50Mbps
Any thoughts on that?
Thanks!
System Configuration: Macintosh / Firefox 65.0
If you are connecting your pc to your mobile hotspot via bluetooth, the throughput will be a much higher rate, then wifi.
