Need help with setting up a LAN
Uh..Peaches
Aug 23, 2009 at 01:25 PM
sharpman Posts 1021 Registration date Saturday May 23, 2009 Status Contributor Last seen October 20, 2010 - Aug 23, 2009 at 05:38 PM
- Need help with setting up a LAN
- Lan settings - Guide
- Cs go lan - Guide
- Wake on lan command - Guide
- Whatsapp time setting - Guide
- Lg tv setting aspect ratio - Guide
sharpman
183
if all you want to do is transfer files from one computer to the next then all you need is a crossover cable.
this can pe purchased from your local pc store.
plug each end of the crossover cable into the network cards of the pcs in question.
make sure that the ip address and subnet mask are set correctly on each pc
ie. pc1 (vista) ip address 192.168.15.1
pc 2 (xp) ip address 192.168.15.2
subnet mask 255.255.255.0
ensure any firewalls are disabled on either pc.
you should now be able to transfer your files fronm one to the other.
alternatively
you could go here
http://www.usbgear.com/USBG-VISTALink.html
and buy the usb transfer cable. a lot less hassle. and probable cheaper than setting up a full blown network.
alternatively
you could go here
