- Networking problem ? how to put three devices
- All networking commands pdf - Guide
- Ps4 too many usb devices connected - Guide
- Can't ping other devices on network - Guide
- How do you right click on most touchscreen devices - Guide
- How to check skype login devices - Guide
9 responses
Yes all three are connected in the router as mentioned earlier..........
you know what are u talking about.........or its me who is not able to "take" sense out of it.
I think all three devices should be in same SUB NET (of course with differrent ip addresses in that SUB NET ) , they should have same identical gateway, ...and after that both pcs should be able to ping each other and also access the printer......which is not the case .......why why
CyborgCop
Tuesday August 25, 2009
12
Aug 25, 2009 at 10:42 PM
an easy way to do it. would be
Have your PC"s be able to communicate with each other
Get the printer to work with one..
Then just share the printer. As opposed to trying to get it to be on the network; like a computer..
Ensure your computers have the same workgroup.
yes it can be done that way but then the pc attached to the printer must be on alway if other pc want to print.
I am not only looking for viable solution but also wants to know the why.....as mentioned in my original posting
CyborgCop
12
Aug 26, 2009 at 10:48 PM
assuming your printer has a network port.. Plug them all up into your router..
they shouldn't have different addresses entirely.. just the ipaddress of each one should be unique.. but the subnet and gateway should be the same.
Ask a question
CyborgCop
12
Aug 28, 2009 at 02:19 AM
my question would be.. where are you getting the gateways from.. for the different computers..
If you have 2 dhcp's active.. that will mess with things.. How about just setting up everything as static.. and see if that works for ya.
I ve tried by placing all threre devices in that same subnet 192.168.1.0 , by asigning the ip addresses to pcs statically but fot some starnge reasons pc 2 stop accessing the printer.
How to disable DHCP.... do I need to diable at the router?
CyborgCop
12
Aug 28, 2009 at 11:54 PM
yea..
CyborgCop
12
Aug 29, 2009 at 10:17 PM
hmm.. i hope I didn't just disable your computers..
when you go to static.. You need to know your router info.. I usually just follow with "whatever" dhcp would've given me.. B/C all the address have to match up for it work..
Your Router has 2 IP address's
The One it's uses on your network (internal)
And an external one that it uses connecting to outside..
It's like a wall..
Anyways..
If you've got all your computer hooked to the router.. then the DHCP will hand out addresses based on what's it's told to do..
By default it should pass out addresses that will work.
So..
PC1 should be like
192.168.15.100 or something similar
255.255.255.0 (subnet)
192.168.15.1 (gateway) (the ipaddress of the device it's routing to; in this case your router)
PC2
192.168.15.101
255.255.255.0
192.168.15.1
Printer
192.168.15.102
255.255.255.0
192.168.15.1 (might not need or have a gateway)
Router
(internal)
192.168.15.1
255.255.255.0
(external)
66.55.52.90 (essentially it's something totally different; and that's why it blocks everything out)
255.255.255.0
Anyways, if for some reason everything goes WYRY.. just reset your router and put all your computers back on DHCP.. should clear everything back up..
Here's a demo setup.. so.. when I look at your first post.. I think that's really where the problem is.. B/c you have different IP address's and different gateways.. I'm not a professional in networking so I can't tell you why that particular setup works for you.. But I can access your printer/network problem.
It's like a wall..
Anyways..
So..
PC1 should be like
PC2
192.168.15.101
255.255.255.0
192.168.15.1
Printer
192.168.15.102
255.255.255.0
Router
(internal)
192.168.15.1
255.255.255.0
(external)
255.255.255.0
