Plug and play monitor problem: "No signal&quo
bugde - Sep 13, 2009 at 11:59 PM
 kevin - Dec 5, 2009 at 12:19 PM
Just purchased a monitor for my HP notebook PC. Plugged in the cable and turned monitor on. However, the monitor says, "no signal". The CD with the monitor is of no help. Nothing I seemed to try to get a driver recognized helps. Help please.
Sep 14, 2009 at 06:46 AM
You will have to set your display settings and activate your monitor!
Right Click on your desktop and select Display properties,
Select your monitor and press OK
Or Just press the keyboard function for external monitor display!
Fn+ F5 key depending on your system
you cant click on desktop when the moniter is in sleep mode
