How to configure LAN connection for 15 system
sathish - Sep 23, 2009 at 09:35 AM
dancedhall Posts 3056 Registration date Wednesday May 13, 2009 Status Member Last seen March 12, 2010 - Sep 23, 2009 at 10:33 AM
how to configure LAN conncetion for 15 systems in my office pls give step by step and what are all the devices to be needed to that
dancedhall Posts 3056 Registration date Wednesday May 13, 2009 Status Member Last seen March 12, 2010 655
hi there,
you will need a router,modem/switch
configure the router by following steps in manual book
then connect the uplinks to the router modem or even a patch panel
and from there
connect the lan cable to each pc and configure the ip address
either manual or automatic
