No Sound, no audio device, and unknowns
Hubie
Wednesday August 6, 2008
Aug 7, 2008 at 02:28 AM
HizkiaN - Feb 11, 2013 at 01:00 AM
- Unknown device on high definition audio bus
- Looks like we can't get you in your account on this device. please try signing in from the device you use most often. - Yahoo Mail Forum
- Audio device on high definition audio bus ✓ - Drivers Forum
- Network card definition - Guide
26 responses
I have been having this very problem and have been having no luck until a few minutes ago.
I noticed that there was a problem with ->There are no active mixer devices available
error in Windows XP <- There are no active mixer devices available when opening volume control, I went here and found the problem and solution.
Although the sound card and its drivers are installed correctly. I receive this error message about no active mixer devices when I try to double-click on the Volume icon in the system tray
of Windows XP.
Most people will assume the sound card itself is having difficulty or the drivers have no been installed, or maybe the system has been muted. However, when the computer
starts or shuts down you hear the normal Windows sounds. However other audio does not play normally and results in error messages.
Troubleshooting the Error
When I checked the Sound and Audio Devices section of the Control Panel in Windows XP, it shows there are no audio devices and everything is grayed out.
Then I checked the System Devices section of the Control Panel to make sure the sound card was installed correctly and all drivers were installed. As you can see below, the sound card in this case the Realtek High Definition Audio card is installed and working properly.
Solution
It turns out the problem for this error lies in the Windows Audio Service, which usually starts automatically when the sound card is installed and working. However, in this case the service was turned off. Follow the instructions below to reactivate the Windows Audio service.
1) Click on Start and Run
2) Type the following command and press Enter
services.msc
3) Scroll down to Windows Audio in the right-hand column and double-click on it,
4) Make sure the Startup Type is set to Automatic and click on the Start button under Service Status. The Windows Audio service should restart and the error with the volume control should be resolved.
REPOSTED FROM: http://www.pchell.com/support/no_active_mixer_devices_available.shtml
of Windows XP.
Solution
services.msc
Jun 9, 2010 at 02:38 PM
Jun 21, 2010 at 06:42 AM
