Dell Inspiron 1525 base system device problem [Solved/Closed]
dae; - Jan 4, 2010 at 07:50 PM - Latest reply:  helmert
- Dec 7, 2017 at 09:01 AM
i have a problem with my Dell Inspirion 1525 laptop.
i suddenly seem to be able to connect to the interent wirelessly only when I am DIRECTLY next to the router
& I see that in my computer's properties the word "Base System Devices" is shown twice with an exclamation mark..
what is the problem, can I fix it myself, and is that what has my wifi connection horrible all of a sudden??
thankyou,
any help is greatly appreciated!
gadow21 13 Posts Wednesday April 28, 2010Registration date April 29, 2010 Last seen - Apr 28, 2010 at 11:07 AM
+90
18
I had the exact same issue, and it drove me nuts trying to figure out which is the correct driver that I am missing. I finally found which one the "Base System Device" driver is, and what device it was pointing to.
To fix the issue, you need to go to Dells device & drivers website, and go to the Inspiron 1525 drivers site. Then, choose Windows XP, and once that site comes up, you need to choose Chipset, and download the Ricoh driver. There is only two of them listed, one is a Intel for your regular chipset, and then the Ricoh driver for you flash card driver. Here is the actual link to the correct driver you need to fix all three "Base System Device" bangs.
http://www.dell.com/support/drivers/us/en/04/DriversHome/NeedProductSelection
After you install this file, and reboot your machine, you should be good. If you have any questions, please dont hesistate to ask. By the way, I am a CompTIA A+ and Net+ Certified computer technician, so if you need help, I am the man to ask.
Was this answer helpful?
well done good for you and half of the world have comptia its easy to get hold of them
^^ By the way, I am a CompTIA A+ and Net+ Certified computer technician, so if you need help, I am the man to ask.
I hope your mother is very proud of you! Congrats to your very minimal achieve, you ARE the man!
wow what an a$$!!
bedankt hiermee is het probleem opgelost
Zohaib R 2416 Posts Sunday September 23, 2012Registration date November 12, 2017 Last seen - Sep 17, 2013 at 08:21 PM
+1
Hi mark,
If you have Dell Inspiron 1525 Laptop computer, you can download the drivers from here. This driver will fix the three yellow bangs against the devices.
For the network problems follow the below mentioned steps:
1. Reseat network cable on the computer end and also from the modem/router end.
2. Check if Link LEDs blinking at the computer end. If no response, Power cycle modem/router (if any) and try known good cable.
3. If Link LEDS does not show any response with known good cable, the issue is with the motherboard.
4. If Link LEDs does blink or show response but no internet connection follow the next steps.
5. Press and hold the Windows Key on the keyboard and then press R key to launch Run Dialog box.
6. Type "cmd" and hit "Enter".
7. Type "ipconfig" at the command prompt and hit "Enter".
8. Scroll down to the Ethernet Adapter.
9. Under the listed Adapter check if "IPv4" and "Default Gateway" show a valid IP Address.
10. Type "ping IPv4 Address" and hit Enter also ping "Default Gateway". Replace IPv4 address and "Default Gateway" with actual IP Addresses.
11. If you get response in the above step, type "ping www.dell.com" and check if there is response.
12. If Ping is successful in the previous steps and Internet Explorer is unable to open any websites or showing Page cannot be displayed. Run below MS Fix-Its using wired connection:
a. Winsock Reset - Fix it
b. Automatically diagnose and fix common security setting on Windows
c. MS Fix it : Improve performance, safety and security in Internet Explorer
13. If ping is successful for default gateway, but not for websites, check in "Safe Mode With Networking". If you are able to go online in "Safe Mode With Networking", then it's an issue mostly with firewall.
14. If you are not able to ping the website or go online in "Safe Mode With Networking" also, then "Power Cycle" the router (if any).
15. Check if any other computers are able to connect to this same network. If yes, the issue is with this computer.
Hope this helps.
To know more about Dell Product Support, Drivers & Downloads, Order & Dispatch status -> choose your region US Customers; India Customers. For Dell support videos click Here.
+1
thanks..it really worked
Zohaib R 2416 Posts Sunday September 23, 2012Registration date November 12, 2017 Last seen - Jun 26, 2013 at 05:57 AM
Hi fasal3,
This thread was opened for Inspiron 1525, what is the exact System Model Number of your Dell Laptop? Which version of Windows 7 is installed in your computer, it is 32-bit or 64-bit?
To know more about Dell's products, services and drivers & downloads, please go to http://dell.to/YBlak6
