HELP micro sd problem on nokia 5800
darwin25275
Thursday January 7, 2010
Jan 8, 2010 at 04:32 AM
darwin25275 Posts 4 Registration date Thursday January 7, 2010 Status Member Last seen January 10, 2010 - Jan 9, 2010 at 04:51 AM
- HELP micro sd problem on nokia 5800
- Nokia factory reset code forgot - Guide
- Www.gameloft.com unlock code nokia ✓ - Phones, PDA & GPS Forum
- Nokia nitro racing unlock code free ✓ - Nokia Forum
- Unlock code - Phones, PDA & GPS Forum
- Nokia 105 games unlock code free - Nokia Forum
Hi there,
You need to reset the memory card password?right?
If so then link below from Faq will give you instructions for the process:
https://ccm.net/faq/4154-lost-password-to-microsd-card
darwin25275
Hi Suff954, I cann ot find the system folder and I can ot download file explorer as well sis files are not accepted and I can not locate jar file explorer as well, do you have any other suggestions? PLS HELP ME.
