Lenovolaptop wireless switch problem
rajupower Posts 5 Registration date Tuesday January 19, 2010 Status Member Last seen February 14, 2010 - Feb 14, 2010 at 12:23 AM
 bubesh - Jul 31, 2010 at 05:22 AM
lenovo laptop wireless problem
I just recently format my laptop while doing it I kept wireless switch on so that day my wireless does not work. but I re install os once again with wireless switch off but still it is not working.
I have a lenovo G430- B3Q laptop. .
The wireless LED does not light up.
please help to solve it
Thanks,
raju power
Feb 14, 2010 at 03:19 AM
Hi there,
Keeping the wireless switch on or off doesn't make any difference while formatting the system.After formatting you need to install driver on system compatible to type of operating system installed.To download the drivers you can refer to link below from official Lenovo website:
https://support.lenovo.com/fr/en/?lndocid=BATT-LENOVO
Feb 14, 2010 at 11:13 AM
hello
thank you for answer. I installed software but still I have problem even Fn + F5, led is not blinking and blue tooth also not detecting . wireless led will go only at the starting please help me
after install power management software... this problem is sloved ..
Intall power management software... 81u411ww.exe.. this is for win7..
