CPU Fan removed and replaced. Can't power on.
Dein0nychus
Wednesday March 3, 2010
Mar 3, 2010 at 03:08 PM
Dein0nychus Posts 2 Registration date Wednesday March 3, 2010 Status Member Last seen March 4, 2010 - Mar 4, 2010 at 02:08 PM
- CPU Fan removed and replaced. Can't power on.
- Power saving mode in computer - Guide
- Quick cpu - Download - Diagnosis and monitoring
- Power bi download - Download - Data management
- Tinder removed my bio - Guide
Hi there,
Recheck the internal connections as well as on power supply there is a switch ,see whether its not set off.
Dein0nychus
The internal connections are all fine, and the switch on the power supply is turned on. Still won't power on.
