Toshiba laptop won't start, power light on
Maka - May 22, 2010 at 03:57 PM
 Blocked Profile - Sep 3, 2010 at 01:13 AM
Toshiba laptop: will not power up, on/off switch has no effect. However the light on the power switch stays on, will not go off. Depressing power switch has no effect on the light and no effect at all. Does not even begin or 'try' to power up. I am suspecting something in the on/off circuitry.
Any help is certainly appreciated!
Thanks!
Please get through the following instructions for getting the problem solved.
https://ccm.net/computing/hardware/1535-computer-boots-to-black-screen/
Thank you.
-1
