PE Builder Problem. Please Help, Don't Ignore
Jack Rex Posts 177 Registration date Saturday January 2, 2010 Status Member Last seen August 13, 2016 - May 30, 2010 at 01:50 AM
Jack Rex Posts 177 Registration date Saturday January 2, 2010 Status Member Last seen August 13, 2016 - Jun 5, 2010 at 06:49 AM
I put some driversin the drivers folder of PE Builder and started to build an iso. After it finished copying files process, I got 120 errors. They are-
Error: Directory number not found: 16419 (file="C:\PEBUILDER3110A\DRIVERS\NET\DIRECT PARALLEL\SHAREDACCESS.INI")
DecompressOrCopy file "C:\PEBUILDER3110A\DRIVERS\NET\DIRECT PARALLEL\SHAREDACCESS.INI" to ""
Error: SetupDecompressOrCopyFile() "C:\PEBUILDER3110A\DRIVERS\NET\DIRECT PARALLEL\SHAREDACCESS.INI" to "" 3: The system cannot find the path specified.
DecompressOrCopy file "C:\PEBUILDER3110A\DRIVERS\NET\DIRECT PARALLEL\RASIRDA.SYS" to "C:\pebuilder3110a\BartPE\I386\SYSTEM32\DRIVERS\RASIRDA.SYS"
DecompressOrCopy file "C:\PEBUILDER3110A\DRIVERS\NET\DIRECT PARALLEL\NETRASA.INF" to "C:\pebuilder3110a\BartPE\I386\INF\NETRASA.INF"
DecompressOrCopy file "C:\PEBUILDER3110A\DRIVERS\NET\PACKET SCHEDULER MINIPORT\NETPSA.INF" to "C:\pebuilder3110a\BartPE\I386\INF\NETPSA.INF"
Error: Directory number not found: 16419 (file="C:\PEBUILDER3110A\DRIVERS\NET\RAS ASYNC ADAPTER\SHAREDACCESS.INI")
DecompressOrCopy file "C:\PEBUILDER3110A\DRIVERS\NET\RAS ASYNC ADAPTER\SHAREDACCESS.INI" to ""
Error: SetupDecompressOrCopyFile() "C:\PEBUILDER3110A\DRIVERS\NET\RAS ASYNC ADAPTER\SHAREDACCESS.INI" to "" 3: The system cannot find the path specified.
DecompressOrCopy file "C:\PEBUILDER3110A\DRIVERS\NET\RAS ASYNC ADAPTER\RASIRDA.SYS" to "C:\pebuilder3110a\BartPE\I386\SYSTEM32\DRIVERS\RASIRDA.SYS"
DecompressOrCopy file "C:\PEBUILDER3110A\DRIVERS\NET\RAS ASYNC ADAPTER\NETRASA.INF" to "C:\pebuilder3110a\BartPE\I386\INF\NETRASA.INF"
Error: Directory number not found: 16419 (file="C:\PEBUILDER3110A\DRIVERS\NET\WAN MINIPORT (IP)\SHAREDACCESS.INI")
DecompressOrCopy file "C:\PEBUILDER3110A\DRIVERS\NET\WAN MINIPORT (IP)\SHAREDACCESS.INI" to ""
Error: SetupDecompressOrCopyFile() "C:\PEBUILDER3110A\DRIVERS\NET\WAN MINIPORT (IP)\SHAREDACCESS.INI" to "" 3: The system cannot find the path specified.
DecompressOrCopy file "C:\PEBUILDER3110A\DRIVERS\NET\WAN MINIPORT (IP)\RASIRDA.SYS" to "C:\pebuilder3110a\BartPE\I386\SYSTEM32\DRIVERS\RASIRDA.SYS"
DecompressOrCopy file "C:\PEBUILDER3110A\DRIVERS\NET\WAN MINIPORT (IP)\NETRASA.INF" to "C:\pebuilder3110a\BartPE\I386\INF\NETRASA.INF"
Error: Directory number not found: 16419 (file="C:\PEBUILDER3110A\DRIVERS\NET\WAN MINIPORT (L2TP)\SHAREDACCESS.INI")
DecompressOrCopy file "C:\PEBUILDER3110A\DRIVERS\NET\WAN MINIPORT (L2TP)\SHAREDACCESS.INI" to ""
Error: SetupDecompressOrCopyFile() "C:\PEBUILDER3110A\DRIVERS\NET\WAN MINIPORT (L2TP)\SHAREDACCESS.INI" to "" 3: The system cannot find the path specified.
DecompressOrCopy file "C:\PEBUILDER3110A\DRIVERS\NET\WAN MINIPORT (L2TP)\RASIRDA.SYS" to "C:\pebuilder3110a\BartPE\I386\SYSTEM32\DRIVERS\RASIRDA.SYS"
DecompressOrCopy file "C:\PEBUILDER3110A\DRIVERS\NET\WAN MINIPORT (L2TP)\NETRASA.INF" to "C:\pebuilder3110a\BartPE\I386\INF\NETRASA.INF"
Error: Directory number not found: 16419 (file="C:\PEBUILDER3110A\DRIVERS\NET\WAN MINIPORT (PPPOE)\SHAREDACCESS.INI")
DecompressOrCopy file "C:\PEBUILDER3110A\DRIVERS\NET\WAN MINIPORT (PPPOE)\SHAREDACCESS.INI" to ""
Error: SetupDecompressOrCopyFile() "C:\PEBUILDER3110A\DRIVERS\NET\WAN MINIPORT (PPPOE)\SHAREDACCESS.INI" to "" 3: The system cannot find the path specified.
DecompressOrCopy file "C:\PEBUILDER3110A\DRIVERS\NET\WAN MINIPORT (PPPOE)\RASIRDA.SYS" to "C:\pebuilder3110a\BartPE\I386\SYSTEM32\DRIVERS\RASIRDA.SYS"
DecompressOrCopy file "C:\PEBUILDER3110A\DRIVERS\NET\WAN MINIPORT (PPPOE)\NETRASA.INF" to "C:\pebuilder3110a\BartPE\I386\INF\NETRASA.INF"
Error: Directory number not found: 16419 (file="C:\PEBUILDER3110A\DRIVERS\NET\WAN MINIPORT (PPTP)\SHAREDACCESS.INI")
DecompressOrCopy file "C:\PEBUILDER3110A\DRIVERS\NET\WAN MINIPORT (PPTP)\SHAREDACCESS.INI" to ""
Error: SetupDecompressOrCopyFile() "C:\PEBUILDER3110A\DRIVERS\NET\WAN MINIPORT (PPTP)\SHAREDACCESS.INI" to "" 3: The system cannot find the path specified.
DecompressOrCopy file "C:\PEBUILDER3110A\DRIVERS\NET\WAN MINIPORT (PPTP)\RASIRDA.SYS" to "C:\pebuilder3110a\BartPE\I386\SYSTEM32\DRIVERS\RASIRDA.SYS"
DecompressOrCopy file "C:\PEBUILDER3110A\DRIVERS\NET\WAN MINIPORT (PPTP)\NETRASA.INF" to "C:\pebuilder3110a\BartPE\I386\INF\NETRASA.INF"
DecompressOrCopy file "C:\PEBUILDER3110A\DRIVERS\PORTS\COMMUNICATIONS PORT\PARPORT.SYS" to "C:\pebuilder3110a\BartPE\I386\SYSTEM32\DRIVERS\PARPORT.SYS"
DecompressOrCopy file "C:\PEBUILDER3110A\DRIVERS\PORTS\COMMUNICATIONS PORT\SERIAL.SYS" to "C:\pebuilder3110a\BartPE\I386\SYSTEM32\DRIVERS\SERIAL.SYS"
DecompressOrCopy file "C:\PEBUILDER3110A\DRIVERS\PORTS\COMMUNICATIONS PORT\SERENUM.SYS" to "C:\pebuilder3110a\BartPE\I386\SYSTEM32\DRIVERS\SERENUM.SYS"
DecompressOrCopy file "C:\PEBUILDER3110A\DRIVERS\PORTS\COMMUNICATIONS PORT\MSPORTS.INF" to "C:\pebuilder3110a\BartPE\I386\INF\MSPORTS.INF"
DecompressOrCopy file "C:\PEBUILDER3110A\DRIVERS\PORTS\ECP PRINTER PORT\PARPORT.SYS" to "C:\pebuilder3110a\BartPE\I386\SYSTEM32\DRIVERS\PARPORT.SYS"
DecompressOrCopy file "C:\PEBUILDER3110A\DRIVERS\PORTS\ECP PRINTER PORT\SERIAL.SYS" to "C:\pebuilder3110a\BartPE\I386\SYSTEM32\DRIVERS\SERIAL.SYS"
DecompressOrCopy file "C:\PEBUILDER3110A\DRIVERS\PORTS\ECP PRINTER PORT\SERENUM.SYS" to "C:\pebuilder3110a\BartPE\I386\SYSTEM32\DRIVERS\SERENUM.SYS"
DecompressOrCopy file "C:\PEBUILDER3110A\DRIVERS\PORTS\ECP PRINTER PORT\MSPORTS.INF" to "C:\pebuilder3110a\BartPE\I386\INF\MSPORTS.INF"
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FMAIBHS.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FMAIBHS.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FMAIBHS.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FDSPBHS.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FDSPBHS.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FDSPBHS.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FJBCBHS.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FJBCBHS.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FJBCBHS.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FCONBHS.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FCONBHS.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FCONBHS.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FPRMBHS.PRM")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FPRMBHS.PRM" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FPRMBHS.PRM" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FOKABHS.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FOKABHS.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FOKABHS.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66002 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_DCINST.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_DCINST.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_DCINST.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FVIFBHS.VIF")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FVIFBHS.VIF" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FVIFBHS.VIF" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FUICBHS.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FUICBHS.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FUICBHS.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FBSRBHS.EXE")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FBSRBHS.EXE" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FBSRBHS.EXE" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FUIRBHS.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FUIRBHS.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FUIRBHS.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FUI1BHS.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FUI1BHS.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FUI1BHS.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FCF0BHS.CFG")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FCF0BHS.CFG" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FCF0BHS.CFG" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FGRCBHS.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FGRCBHS.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FGRCBHS.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FPRUBHS.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FPRUBHS.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FPRUBHS.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FPREBHS.EXE")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FPREBHS.EXE" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FPREBHS.EXE" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_QI091E.CHM")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_QI091E.CHM" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_QI091E.CHM" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\EPSET32.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\EPSET32.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\EPSET32.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_DP1BHE.DAT")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_DP1BHE.DAT" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_DP1BHE.DAT" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66003 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FICMBHS.ICM")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FICMBHS.ICM" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FICMBHS.ICM" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FHM0BHS.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FHM0BHS.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FHM0BHS.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FMW0BHS.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FMW0BHS.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FMW0BHS.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FHT0BHS.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FHT0BHS.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FHT0BHS.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FSR0BHS.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FSR0BHS.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FSR0BHS.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FHBRBHS.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FHBRBHS.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FHBRBHS.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FHUTBHS.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FHUTBHS.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FHUTBHS.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FHUTBHS.EXE")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FHUTBHS.EXE" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FHUTBHS.EXE" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FHSRBHS.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FHSRBHS.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FHSRBHS.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FBAPBHS.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FBAPBHS.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FBAPBHS.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FBBIBHS.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FBBIBHS.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FBBIBHS.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FBIDBHS.LMD")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FBIDBHS.LMD" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FBIDBHS.LMD" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FBLPBHS.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FBLPBHS.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FBLPBHS.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FBIDBHS.DAT")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FBIDBHS.DAT" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FBIDBHS.DAT" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\EBPSHRE4.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\EBPSHRE4.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\EBPSHRE4.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\SAGENT4.EXE")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\SAGENT4.EXE" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\SAGENT4.EXE" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\EBPSAGT4.DAT")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\EBPSAGT4.DAT" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\EBPSAGT4.DAT" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FBAGBHS.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FBAGBHS.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FBAGBHS.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66002 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FLBBHS.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FLBBHS.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FLBBHS.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66002 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FD4BBHS.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FD4BBHS.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FD4BBHS.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\EPUPDATE.EXE")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\EPUPDATE.EXE" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\EPUPDATE.EXE" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\EPUPDATE.DAT")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\EPUPDATE.DAT" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\EPUPDATE.DAT" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FARNBHS.EXE")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FARNBHS.EXE" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FARNBHS.EXE" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FASKBHS.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FASKBHS.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FASKBHS.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FAMTBHS.EXE")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FAMTBHS.EXE" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FAMTBHS.EXE" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FAMDBHS.EXE")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FAMDBHS.EXE" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FAMDBHS.EXE" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FAIRBHS.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FAIRBHS.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FAIRBHS.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FAPRBHS.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FAPRBHS.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FAPRBHS.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FATIBHS.EXE")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FATIBHS.EXE" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FATIBHS.EXE" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FABRBHS.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FABRBHS.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FABRBHS.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FASRBHS.DLL")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FASRBHS.DLL" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FASRBHS.DLL" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FBINBHS.EXE")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FBINBHS.EXE" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FBINBHS.EXE" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FAIFBHS.DAT")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FAIFBHS.DAT" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_FAIFBHS.DAT" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_S00RP1.EXE")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_S00RP1.EXE" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_S00RP1.EXE" to "" 3: The system cannot find the path specified.
Error: Directory number not found: 66000 (file="C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_QIAL2E.CHM")
DecompressOrCopy file "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_QIAL2E.CHM" to ""
Error: SetupDecompressOrCopyFile() "C:\pebuilder3110a\drivers\Printer\EPSON Stylus C58 Series\E_QIAL2E.CHM" to "" 3: The system cannot find the path specified.
Can anyone please help me.
Thanks in advance
Jun 3, 2010 at 10:01 AM
Please explain yourself correctly for appropriate help.
Thank you.
Jack Rex Posts 177 Registration date Saturday January 2, 2010 Status Member Last seen August 13, 2016 7
Somebody please help me. Don't ignore my post. I backed up the drivers using double drivers. Copied those to the drivers in pe builder and also copied the appropriate dlls and syss. Then these errors.
