External Hard Drive case problem
graeme50
Saturday June 19, 2010
Jun 19, 2010 at 02:41 PM
graeme50 Posts 3 Registration date Saturday June 19, 2010 Status Member Last seen June 20, 2010 - Jun 20, 2010 at 01:38 AM
- External Hard Drive case problem
- Hard drive regenerator - Download - Backup and recovery
- Wd drive unlock - Guide
- Hard drive diagram - Guide
- How to install a second hard drive windows 11 - Guide
Try the following...
To take ownership of a folder
1.Right-click the folder that you want to take ownership of, and then click Properties. (you will want to take ownership of the my documents folder, if you cannot get that far down without errors, try simply the Documents and Settings folder.)
2.Click the Security tab, click Advanced, and then click the Owner tab.
3.Click Edit. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
4.Click the name of the person you want to give ownership to.
5.If you want that person to be the owner of files and subfolders in this folder, select the Replace owner on subcontainers and objects check box.
6.Click OK.
6.Click OK.
