Theres no audio and sound device !
ansisblaus
Tuesday June 22, 2010
Jun 22, 2010 at 05:23 AM
kristain Posts 69 Registration date Friday March 12, 2010 Status Member Last seen May 30, 2011 - Jun 22, 2010 at 06:28 AM
- Theres no audio and sound device !
- 123movies no sound ✓ - Hardware Forum
- Dfx audio enhancer - Download - Other
kristain
20
Reboot, enter the bios, disable the onboard audio, game port, and midi. then boot back into windows, go to add remove programs, make sure any program for the device was removed. turn the computer off, put in the card, boot up, then use the install cd. the problem is (more than likely) the default device in audio properties is still the onboard, you can select the creative devices and it will probably work, but it will be better to disable the onboard all together.
For more info visit http://www.iyogi.ca/computer-Support/hp-computer-support.html
