My CPU temp is 85 and my fan speed is 850
Sayed
Jul 24, 2010 at 07:45 AM
xpcman Posts 19530 Registration date Wednesday October 8, 2008 Status Contributor Last seen June 15, 2019 - Jul 25, 2010 at 07:09 PM
- My CPU temp is 85 and my fan speed is 850
- Need for speed most wanted 2005 - Download - Racing
- Blackmagic disk speed test windows - Download - Diagnosis and monitoring
- Need for speed unbound free download - Download - Racing
- Temp file cleaner - Download - Cleaning and optimization
- Core temp - Download - Diagnosis and monitoring
1,827
sometimes the BIOS has an option to set fan speeds or turn on/off auto speed control. You could try turning off auto fan control and keep it a high speed.
1,827
Jul 24, 2010 at 02:37 PM
85 C ? That's way too hot. the fan speed is way too low.
If this is a desk top computer I would replace the entire CPU cooler and fan with a new one. On a laptop about the only thing you can do is try to blow out the dust from the computer. The next step is to take it to a local repair shop.
Ambucias
Monday February 1, 2010
11,171
Jul 25, 2010 at 04:31 PM
Excuse me for interrupting. Are you talking about celcius or farenheit?
