HP laptop LCD won't work, external won't work
neema
Sep 7, 2010 at 09:42 PM
closeup22 Posts 8923 Registration date Friday May 15, 2009 Status Member Last seen October 7, 2010 - Sep 8, 2010 at 08:47 AM
- HP laptop LCD won't work, external won't work
- How to type # in laptop - Guide
- Laptop won't type - Guide
- Gta 5 download free laptop hp - Download - Action and adventure
- Hp smart download windows 10 - Download - Other
- Camera not working on hp laptop - Guide
closeup22
Friday May 15, 2009
2,099
Hi there,
Please check the connections on board and close the laptop well before powering on as all parts have a connection in between and is a signal is not being sent or received then it will never power on,if you are confused then better send it to a professional electronic technician and have it be fixed instead of complicating the situation,
richardriley
Wednesday September 8, 2010
Sep 8, 2010 at 06:14 AM
The first step is to turn off the notebook and take out the battery. The next step is to examine the bezel for screws. Then after removing the screws, carefully pull the bezel out. After you have detached the frame away from the screen, examine the back of the LCD panel. The next step is to disconnect the connectors that connect the screen to the notebook. Finally, install the new LCD screen. I found this site when i was searching for a detail step by step on how to replace my LCD screen. http://laptoptroubleshoot.com I hope it helps.
