Low speed for downloading,help me sir
rony - May 9, 2011 at 11:06 AM
 Anonymous User - May 10, 2011 at 11:29 AM
Hello, sir
i'm using the bsnl unlimited broadband plan,they offer 256kb speed,but i'm getting 20kb speed for downloading,
windows7 is the operating system,internet explorer9 is using now
pls help me sir
4 responses
Anonymous User
May 9, 2011 at 12:07 PM
Try with a speed booster for internet,you will get it on this link:
http://ccm.net/download/download-3672-internet-cell-boost
sir it's not working,i download the software,but they said
the following minimum requirement for this setup were not met
windows7 ultimate,ram 1gb,internet explorer9.
.please help me to increase the downloading speed.
help me sir,i did not get any answer.pls help me,
waiting for ur favourable rply.
Anonymous User
May 10, 2011 at 05:26 AM
Here's a simple little thing you can do to increase your bandwidth by at least 20%.
Ok here we go...
1.) log on as Administrator.
2.) start - run - type gpedit.msc
3.) expand "local computer policy"
4.) then expand "administrative templates"
5.) then expand "network branch"
6.) Highlight the "QoS Packet Scheduler"
7.) on right window double click "limit reservable bandwidth"
8.) on setting tab check the "enabled"
9.) change "Bandwidth limit %" to 0
You're done.It would be a good idea to reboot after this.
thanku............... sir.it's working
pls give me one more help
how to increase downloading speed of utorrent?
now my speed is 30kb.some times it's moves to 5kb.it's very difficult to download movies.Is there any way to increase my speed upto 50kb constanly.pls help me to solve this problem too
windows7 ultimate,internet explorer9,ram 1gb.
Anonymous User
May 10, 2011 at 10:54 AM
Try this 1.
Click on the below link and follow the instructions.
https://ccm.net/apps-sites/software/1703-how-to-improve-utorrent-download-speeds/
Good Luck.
thanks 4 ur help
Anonymous User
You're totally welcome Rony! Please mark the thread as solved if it is.
