How to fix a no sound device install problem
Tank77 - Jun 14, 2011 at 07:15 AM
 Anonymous User - Jun 14, 2011 at 02:17 PM
right click on the speaker icon on your task bar at the right bottom corner of your screen and click on play back device then right click inside the sound window and click on show disabled devices click on the disabled device and click enable this will fix your problem
Anonymous User
Thank you for the Tip!
