Urgent help need Hard disk partition problem
- Urgent help need Hard disk partition problem
- Blackmagic disk speed test windows - Download - Diagnosis and monitoring
- Working of hard disk with diagram - Guide
- Hard disk regenerator - Download - Backup and recovery
- Partition find and mount - Download - Backup and recovery
- Floppy disk fail 40 - Guide
Jun 23, 2011 at 03:16 AM
Go to "Disk Management" --> Right-click on that partition --> Select the option
"Change Drive Letter and Paths" --> Click on the "Add" button and assign any
drive letter to that partition --> Click on OK.
Jun 23, 2011 at 01:05 PM
thanks again...
Apr 20, 2014 at 04:17 PM
after that
Error
Operation failed
What 2 do now?
