Help a MARINE, recycler virus, need help
G
Jan 11, 2012 at 09:41 AM
Ambucias Posts 47356 Registration date Monday February 1, 2010 Status Moderator Last seen February 15, 2023 - Jan 14, 2012 at 03:26 PM
- Help a MARINE, recycler virus, need help
- Goose virus - Download - Other
- Can a jpg have a virus - Guide
- Online virus scan - Guide
- Chrome redirect virus - Guide
- Autorun.inf virus - Guide
6 responses
new problem. i tried a way to fix it. using the CMD and task manager. but i clicked something on the task manager and now all that shows up when i bring up the window is the user, no processes or networking. nothing but the user. i cant exit it except from the task bar below. the only 2 options i have on the window is log off and disconnect user. any ideas?
Anonymous User
Jan 11, 2012 at 11:02 PM
but i clicked something on the task manager and now all that shows up when i bring up the window is the user, no processes or networking///
Double click on edge of task manager,you should get back other things
For recycler issue
Click on the below link and download the file "AutorunExterminator"
https://ccm.net/downloads/security-and-maintenance/5911-autorun-exterminator/
Extract it --> Double-click on "AutorunExterminator" -
This will remove the recycler from the drives.
Step 2:
For xp ,go to RUN and type
cmd and click ok
For vista and 7
Go to start and type
cmd
Now right click on it and select run as administrator
Now run this command
attrib -h -r -s /s /d g:\*.*
where g refers to your external hard drive letter
this should unhide your files
Make sure to run a full scan with
https://ccm.net/downloads/security-and-maintenance/4621-malwarebytes-anti-malware/
For recycler issue
Step 2:
cmd and click ok
For vista and 7
cmd
thanks. is there any other way to do it with out the auto run exterminatoor. i cant hook my lap top up to the internet. due to operational security. (military) any other ideas?
Ambucias
11,176
Jan 13, 2012 at 05:40 AM
Hello to you G and Sundar,
Sundar's solution is the very best.
G, to correspond with Kioskea, you must have Internet and the Exterminator tool is on the Kioskea download section.
Download it from where you are and then transfer the tool to a pendrive or flash drive, you can then again run it on the sick machine.
Regards
P.S. I hope your Commander in Chief will call you back home from hell very soon. Good luck
Regards
Ask a question
Looks like im just going to have to deal with it tell i get back. there are no portable storage devices allowed to be plugged in. last time that happened the government got caught with its pants down. wiki links. lol they are still a lil sore about that. but thanks for the help. it means alot. stay safe and take it easy.
semper fi,
G
semper fi,
G
Ambucias
11,176
Hi G,
Look at this link which solved a problem similar to yours which does not require any download. It may inspire you.
https://ccm.net/forum/affich-63526-how-to-remove-autorun-inf-virus-open-hidden
It seems that four marines also got caught with their pants down with their portable devices! :)
Ambucias
Capt (ret)
R22R
Ambucias
Capt (ret)
R22R
