Checking monitor cable and VGA connections
lollie
Mar 16, 2012 at 12:44 PM
xpcman Posts 19530 Registration date Wednesday October 8, 2008 Status Contributor Last seen June 15, 2019 - Mar 17, 2012 at 11:15 AM
- No connection check signal cable lenovo
- D sub no signal ✓ - CPU & Desktop Forum
- Unsupported signal check device output ✓ - Laptop Forum
- Check soft - Download - Finance
- LG monitor it keeps saying D- Sub, power saving mode - Monitor Forum
1,827
Mar 16, 2012 at 12:50 PM
First boot the computer into "safe mode". (use F8 after you see the Windows logo) Safe mode will use a standard vga mode of 800x600 and 60 hertz. This should display on your old monitor. I suspect your default resolution settings on you new computer are out of the acceptable range of the old monitor.
Mar 16, 2012 at 12:59 PM
Mar 16, 2012 at 01:41 PM
Mar 16, 2012 at 02:06 PM
