No sound with HDMI and can't edit digital audio setting
Raya34
Wednesday October 3, 2012
Oct 3, 2012 at 10:43 AM
Zohaib R Posts 2368 Registration date Sunday September 23, 2012 Status Member Last seen December 13, 2018 - Oct 6, 2012 at 02:01 AM
- No sound with HDMI and can't edit digital audio setting
- Digital audio hdmi driver - Download - Drivers
- Digital convergence - Guide
- Why is there no sound on my tv when connected to the laptop with hdmi windows 11 - Guide
- Soundmax integrated digital audio - Download - Drivers
69
Oct 4, 2012 at 05:56 AM
Hi Raya34,
Please let me know what type of cable is used to connect the computer to the TV? Is it a direct HDMI to HDMI cable or a dongle/adapter such as DVI to HDMI? Also reply with the TV model number so that I can look into the details.
Do reply with results.
Raya34
Oct 4, 2012 at 09:36 AM
It is a regular HDMI cable and a Toshiba flat screen, about 4 years old, not sure of the model number. Used it with a different computer in the past and never had this issue. Thanks!
69
Hi Raya34,
As you have mentioned you had tried it in the past, I would recommend trying the same cable with another machine if available. Also try a different cable if possible. In most of the cases the audio issue is fixed when cable is replaced.
