My sound doesn't work after installing realtek audio driver
krishnanb47
Sunday December 30, 2012
Dec 30, 2012 at 07:12 AM
shruthi - Feb 21, 2017 at 07:24 AM
- Hdaudio\func_01&ven_10ec&dev_0887&subsys_1458a002&rev_1003
- Xbox 360 controller driver - Download - Drivers
- Realtek ac97 audio driver - Download - Drivers
- Audio track download for mx player - Audio Forum
- Realtek high definition audio driver - Download - Drivers
Sunday September 23, 2012
69
Dec 30, 2012 at 11:00 PM
Hi krishnanb47,
Installing a generic driver for the sound card might fix the problem. Do reply with the Device Instance ID of the Sound Card so that I can find a generic driver for the Sound Card in your computer. To get the Device Instance ID of the Sound Card:
1. Right click the Computer icon on the Desktop.
2. Select Manage.
3. Select Device Manager under Computer Management from the left pane.
4. Then expand the device such as "Sound, video and game controllers" or "Network Adapter" from right pane.
5. Right click the Device listed.
6. Click Properties.
7. Go to the Details tab, and then select Device Instance Id from the drop down list.
8. Make a note of this Device Instance ID.
Please do write back to us.
2. Select Manage.
Dec 31, 2012 at 12:43 AM
Dec 13, 2013 at 02:54 AM
I am having a similar problem with my PC and I was hoping you could help me out.
If I tell you my sound card ID, could you help me out, if you can this helps a lot
and thanks. I will ned instructions on how to find out my sound card ID as I
am usuing windows 7, and hence cannot use the description you left earlier.
Please respond ASAP.
Jun 16, 2016 at 01:41 PM
