VB issue with delete rows with specific values
weenie
Saturday July 3, 2010
Jan 13, 2013 at 01:58 PM
rizvisa1 Posts 4478 Registration date Thursday January 28, 2010 Status Contributor Last seen May 5, 2022 - Jan 23, 2013 at 09:36 PM
- VB issue with delete rows with specific values
- How to delete whatsapp account without login - Guide
- Vb editor download - Download - IDE
- How to delete whatsapp account without phone - Guide
- Delete snapchat - Guide
- Yahoo search history delete - Guide
rizvisa1
766
Jan 13, 2013 at 03:15 PM
Try this. instead of adding to range, have a temp column where you put 1, if true and 0 if false
Then filter on appropriate condition
delete all visible rows
weenie
Jan 13, 2013 at 08:02 PM
Tyring to figure out what I have wrong keep getting Syntax error. When I run just 1 criteria works like a charm as you stated to add 1 for true in a temp column. So, I figured works with 1 criteria I can expand on criteria aditions but no dice.
Sub fig1()
' To look up a value in a col. then enter a 1=true on next column
Dim LR As Long, I As Long
With Sheets("Raw Data")
LR = .Range("M" & Rows.Count).End(xlUp).Row
For I = 2 To LR
**this is area has syntax error** If .Range("M" & i).Values = "1E+17", "1E-17" , "1E+30", "1.5E+30","1" And .Range("N" & i).Value = "" Then
With .Range("N" & i)
.Value = "1"
End With
End If
Next i
End With
End Sub
Thanks,
Weenie
Sub fig1()
For I = 2 To LR
.Value = "1"
End With
End If
Next i
End With
End Sub
Thanks,
Weenie
rizvisa1
766
Jan 13, 2013 at 09:30 PM
try this
With Range(Cells(2, "N"), Cells(lr, "N")) .NumberFormat = "general" .FormulaR1C1 = "=if(rc[-1]="""",0,IF(OR(RC[-1]=1E+17,RC[-1]=0,RC[-1]=1E-17,RC[-1]=1E+30,RC[-1]=1.5E+30),1,0))" Application.CutCopyMode = False .Copy .PasteSpecial xlPasteValues Application.CutCopyMode = False End With
Thanks. It works like a charm and fast. But I have another issue I have read up on autofilter & making it visible cells only to copy and paste to different sheet. I am having a problem with it copying and pasting. At your suggestion I made a temp column and did 0 & 1. I want to take it a step further: filter by selecting 1's only, copy non-contigious rows to different sheet2, go back to orginal sheet1 and delete rows of the 1's criteria.
ActiveSheet.Range("$A$1:$N$200000").AutoFilter Field:=14, Criteria1:="1"
'Offset 1 Row to exclude headings
Set FilterRange = ActiveSheet.UsedRange.Offset(1, 0).SpecialCells(xlCellTypeVisible)
FilterRange.Copy Destination:=Sheets("Failure Data").Range("A2")
'We use the ActiveSheet since has the data we want to delete
With Sheets("Raw data")
'Set the first and last row to loop through row start at & the column you want to look at
Firstrow = 2
Lastrow = Cells(Rows.Count, "N").End(xlUp).Row
'We loop from Lastrow to Firstrow (bottom to top)
For Lrow = Lastrow To Firstrow Step -1
'We check the Name WE WANT DELETED in the column in this example
With Cells(Lrow, "N")
If Not IsError(.Value) Then
If .Value = "1" Then .EntireRow.Delete
'This will delete each row with the Value
End If
End With
Next Lrow
End
Firstrow = 2
End If
End With
Next Lrow
End
So I was curious as to many records I have of "1" criteria from autofilter results. It showed I had 25,240 records from total 194,401 (number rows will always vary for each file I have to run). I keep getting error not sure as to why. From what I have noticed is 8179 instances is max "areas" will allow and I'm sure amount I have is exceeding. I havent attempted to delete the filtered rows since I can not even manage to paste the 25,240 rows of filtered criteria without it pasting ALL rows filtered & non-filtered.I tried recoding macro steps of copying or deleting filtered rows and I get error of area/rectangle and will proceed to either copy/delete all. Majorly stuck any help be appreciated
Sub TryAutoFilter()
Dim worksheet1 As Worksheet
Set worksheet1 = Worksheets("Raw Data")
With worksheet1
.AutoFilterMode = False: .Rows(1).AutoFilter
.Rows(1).AutoFilter Field:=CStr(14), Criteria1:="=1"
**Next line below is where I get error**
If .AutoFilter.Range.Columns(14).SpecialCells(xlCellTypeVisible).Count - 1 = 1 Then
.Range("A1").CurrentRegion.Offset(1, 0).SpecialCells(xlCellTypeVisible).Copy _
Destination:=Worksheets("Sheet3").Range("A1")
Else
MsgBox "No data to copy"
End If
End With
End Sub
Thanks,
Weenie
Sub TryAutoFilter()
With worksheet1
Else
End If
End With
End Sub
Thanks,
Weenie
rizvisa1
766
Jan 21, 2013 at 08:23 PM
I am not sure what you asked later. You dont have to delete row by row,
try this
try this
Sub fig1() ' To look up a value in a col. then enter a 1=true on next column Dim LR As Long, I As Long Dim lastColumn As Long With Sheets("Raw Data") .AutoFilterMode = False LR = .Range("M" & Rows.Count).End(xlUp).Row lastColumn = .Cells(1, .Columns.Count).End(xlToLeft).Column With Range(Cells(2, "N"), Cells(LR, "N")) .NumberFormat = "general" .FormulaR1C1 = "=if(rc[-1]="""",0,IF(OR(RC[-1]=1E+17,RC[-1]=0,RC[-1]=1E-17,RC[-1]=1E+30,RC[-1]=1.5E+30),1,0))" Application.CutCopyMode = False .Copy .PasteSpecial xlPasteValues Application.CutCopyMode = False End With 'you should select all cells rather as range as on times empty cells cause issues .Cells.AutoFilter Field:=14, Criteria1:="1" Application.CutCopyMode = False .Range(.Cells(2, 1), .Cells(LR, lastColumn)).Copy Sheets("Failure Data").Range("A2").PasteSpecial Application.CutCopyMode = False .Range(.Cells(2, 1), .Cells(LR, lastColumn)).EntireRow.Delete .AutoFilterMode = False End With End Sub
I keep getting Run-time error '1004':
Application-defined or object-defined error where I placed asterisk. Not sure why error since the top half code you supplied works
***** .Range(.Cells(2, 1), .Cells(LR, lastColumn)).Copy
End With
Thanks,
Weenie
End With
Thanks,
Weenie
rizvisa1
766
paste your full routine. May be some thing will show up
