- Power Save mode came on and does not go away
- Power saving mode in computer - Guide
- Save as pdf office 2007 - Download - Other
- Filezilla dark mode - Guide
- Opera mini desktop mode - Guide
- Sceptre monitor no signal entering power save mode ✓ - Windows Forum
9 responses
Wednesday October 8, 2008
1,830
Feb 14, 2009 at 04:42 PM
Are you sure it doesn't say "Attention no signal check input signal connection"? This error message is displayed by the monitor when it does not detect an input signal. The PC is NOT sending a signal to the monitor. Check your cable connections - then you might remove the video card and replace it. (with the PC unplugged). Just about anything past this stage requires a PC technician to fix. Good Luck
My computer shuts down if it sits idile for just 30 seconds it go into energy saver mode. how do I fix this?
My new screen turns off after about 30min. saying analog power saving mode and will not come back on?
1,830
Feb 14, 2009 at 06:55 PM
I assume that this is a desktop PC and not a laptop. (if it's a laptop - take it in for repair - there is nothing you can do)
Trace the video cable back to the PC. The cable can be plugged into two things:
1. a socket on the motherboard near where the keyboard and mouse sockets are
2. a socket on a video card this is in turn plugged into the motherboard (removed from the area of the other sockets).
If you have the second configuration you can remove the case cover - remove the monitor cable - remove the screw holding the video card - remove the video card - dust it off - replace card - reverse the steps and reassemble the PC.
Restart the PC.
If this doesn't work then it's time to take the PC to a repair shop.
Restart the PC.
Ask a question
xpcman,
thank you for your help. You are right, it is "no" not "on".
I have checked the connections and they seem to be okay. where would the video card be and what does it look like?
Jay
Jay
Hello again xpcman,
It seems like the video card is integrated in motherboard. It is Elitegroup Mainboard. I have attached the link for specs.
What do you suggest?? Thank you in advance.
Jay
Jay
I had this problem with a Viewsonic which did it on both a desktop and a laptop. New monitor works with both, so it was a bad monitor.
If your computer has a Video card (not the onboard type), try pulling the video card out of the slot and plugging it back. I have just done this on a computer and it solved the problem. I'm not saying that it will solve your problem but if you haven't done it yet it may solve your problem.
1,830
Feb 14, 2009 at 09:06 PM
I would test the monitor with another computer and test your computer with a different monitor. If the monitor proves to be good you are dealing with a dead video chip on the motherboard or a dead motherboard. You could have a repair shop take a look - one option might be to add a video card to the computer.
