Fn Key problem with volume adjustment
peanut5891
Thursday March 7, 2013
Mar 7, 2013 at 11:27 AM
Zohaib R Posts 2368 Registration date Sunday September 23, 2012 Status Member Last seen December 13, 2018 - Mar 27, 2013 at 12:38 PM
- Fn Key problem with volume adjustment
- Samsung volume increase code - Guide
- Key in laptop - Guide
- Microsoft office 2010 free download full version with key - Download - Office suites
- Anvi folder locker reset key - Guide
- Gta 5 download for pc free full version with license key - Download - Action and adventure
7 responses
ernoczi
Sunday March 24, 2013
Mar 27, 2013 at 08:16 AM
Thanks for support, I did what you asked, but without changes. For a few days I had in mind to re-install windows 7, and so I did today. After I installed the energy management software, anyting worked great, all the hotkeys. After that I installed the winamp program and tried to lower the volume and voila..didn't worked the hotkey, so I found the problem. As a removed the winamp, started again to work the hotkey. I never had this problem before, I have this PC for more than 2 years and never caused me this kind of troubles. Tried to install another winamp, but as I started to install, the hotkey stops to respond. Any thoughts? :)
69
Mar 7, 2013 at 12:47 PM
Please check the below mentioned link, try the fix suggested here and see if this fixes the problem:
https://ccm.net/faq/18976-acer-aspire-one-fn-key-not-working
Do reply with results.
peanut5891
Mar 7, 2013 at 01:37 PM
I try that and there was no launch manager in there. So it did not work but I just fixed my problem I found out from another site. Here is what fixed my problem I went to the acer website and downloaded the launch manager for my pc. Even though that on my pc it say i still had another version. I launch manger installed i clicked install any way and after it install it asked to restart pc, and I clicked yes and now everything is working fine again. The volume go's up and down and mutes brightness works. Hope that helps
69
Mar 7, 2013 at 02:41 PM
I am glad to know that the issue has been fixed. Thank you for providing this wonderful fix, this will definitely help other users in the forum.
Kindly get back if there are any further queries.
Ask a question
ernoczi
Mar 24, 2013 at 06:39 AM
I also have issues regarding with Fn Key + volume adjustment(Fn+left arrow/right), trying to lower or higher the music volume, and not reacting as it should. I have a Lenovo G550 model, and only with the volume I have a problem, the brightness,etc are workung properly. I have installed the Energy Management software, tryed earlier versions too, but with same results.
Any idea? pls
Any idea? pls
69
Mar 26, 2013 at 04:24 PM
Hi ernoczi,
Try to uninstall and then reinstall the "Lenovo Energy Management Driver" and check if this package has any interface to control Fn key function. Earlier "Hotkeys Software" used to have this feature. You can download "Lenovo Energy Management Driver" from the below mentioned link:
https://support.lenovo.com/fr/en/pagenotfound?item=http%3A%2F%2Fsupport.lenovo.com%2Ffr%2Fen%2Fdocs%2Fht072728
69
Hi ernoczi,
Thank you so much for sharing this wonderful update with us. This will surely help other users in the forum. I will try to find an answer to this and will post here once I have the update.
Please get back you have any further queries.
