System unit powers up, the green light is on, the red LED is on and no blinking
nissady
Thursday April 25, 2013
Apr 25, 2013 at 11:50 AM
jack4rall Posts 6428 Registration date Sunday June 6, 2010 Status Moderator Last seen July 16, 2020 - Apr 25, 2013 at 01:41 PM
- Power supply blinking green light
- Acer aspire 3 keyboard light - Guide
- Monitor power light blinking but no display reasons - Laptop Forum
- Monitor No Display Blinking Light, PC Boots - Monitor Forum
- Lg gram power light blinking - Laptop Forum
First check all your connections.
If you notice that your CPU fan is spinning but there is no display in the screen,
then remove the RAM from the slot, clean it and place it back properly or try
another slot. Check your RAM also. Even bad RAM will result in display problem.
If you have no idea about RAM, then click on the below links.
RAM
Removing a RAM
If you are using a graphic card, then remove it and place it back properly.
RAM
Removing a RAM
