Monitor issue Please help!
brokencomputer
Friday June 28, 2013
Jun 28, 2013 at 11:56 AM
Zohaib R Posts 2368 Registration date Sunday September 23, 2012 Status Member Last seen December 13, 2018 - Jul 2, 2013 at 06:35 AM
- Monitor issue Please help!
- Monitor zoomed in - Guide
- Power saving mode monitor - Guide
69
Try the below mentioned steps and reply with results:
1. Check for optimal video resolution in the Monitor OSD (On-Screen-Display) Menu. Run factory reset. Refer monitor's user guide for accurate steps.
2. Check if you can start the computer in BIOS Setup before the screen fades. If the BIOS screen appears, check if the problem occurs here also.
3. If same issue in seen on Dell Logo and in BIOS, follow the below mentioned steps.
4. Ensure Video cable is functional/not damaged (broken/bent pins). Reseat monitor data cable (VGA, DVI, HDMI or Display Port).
5. Run "Monitor self-test/BIST". To run "Monitor self-test/BIST" unplug the monitor's video cable while keeping the power cord plugged in. If a pattern or a box appears on the screen with correct image, the test has passed else, the problem is with the Monitor.
6. If you are using a VGA connection, perform "Auto Adjust" from OSD.
7. Check if the issue persists when the monitor is connected via different video port source or to a different computer. If the issue persists the problem is with the monitor.
To know more about Dell's products, services and drivers & downloads, please go to http://dell.to/YBlak6
