<<<<help>>>my cpu not given the power to the monitor
wsim2000
Sunday August 4, 2013
Aug 4, 2013 at 08:19 PM
xpcman Posts 19530 Registration date Wednesday October 8, 2008 Status Contributor Last seen June 15, 2019 - Aug 4, 2013 at 10:25 PM
- <<<<help>>>my cpu not given the power to the monitor
- Power saving mode monitor - Guide
- Quick cpu - Download - Diagnosis and monitoring
- How to check pc power consumption in windows 11 - Guide
- Power bi download - Download - Data management
i am not satified with his answer.......only moniter problem is that all my motherboard is work properly...cpu only not given the power to monitor other than its work proprly
1,826
Aug 4, 2013 at 10:07 PM
My best guess is your motherboard has failed. I suggest you take the PC to a good repair shop.
