Same XP SP 3 Sound problem
ebolique - Feb 23, 2009 at 10:50 PM
Ku$h Posts 3 Registration date Wednesday February 25, 2009 Status Member Last seen March 3, 2009 - Mar 3, 2009 at 02:53 PM
Hello friends,
I have same problem with the sound after installing XP Professional SP 3. I did install everything that should be.my sound driver is also successfully installed. however there is "PCI Device" still with "!" sign in my device manager window. this was not happening when i re-install XP Professional SP 2. the sound with SP 2 is perfectly working. but when I re-install SP 3, even I have installed all the necessary drivers just as what I have installed in SP 2. its totally mute. every drivers I have installed is the most updated i got from its company's website.
everything is running perfectly well except NO SOUNDS.
its killing me cause i cannot play games with no sound.
hope you have solutions.
thank you in advance for your helps.
ebolique
5 responses
vid32 Posts 7 Registration date Sunday February 22, 2009 Status Member Last seen March 3, 2009 2
Mar 3, 2009 at 02:20 PM
..ok..fisrt download: Uniblue DriverScanner 2009 after u install`t open`t after the scann u will see al the driver`s what u hav on the pc` ut to date or not..u have option to download driver but u cant u need a serial..this i`ll giv` to ya` on u`re imail..just give me u`re imail ..`
hi thanks .. do you know how?
thanks in advance for your help
cheeers!
jmp59 Posts 29296 Registration date Tuesday June 8, 2004 Status Contributor Last seen November 25, 2015 257
Feb 24, 2009 at 12:44 PM
Did u try to Update PCI Device ?
hi, thanks. do you know how? can i download it from the web? i am not too familiar with computer system, i am mostly just using it.
thanks in advance for your help.
Mar 3, 2009 at 01:43 PM
Wanting to re-install ur soudcard ? Run its driver.
Needing a link to download this driver ?
Tell the brand and the model of ur computer. Or of ur Mother Board if ur computer is a no-brand one.
Ask a question
aww` .. i had the same problem and with my NVIDIA .. rly that program rock`zz ty` vid32
