Realtek HD sound problems w/ 5.1 speaker
Problem5.1 Posts 1 Registration date Wednesday November 20, 2013 Status Member Last seen November 20, 2013 - Nov 20, 2013 at 12:19 PM
Keithybub Posts 2 Registration date Friday November 11, 2016 Status Member Last seen November 11, 2016 - Nov 11, 2016 at 12:46 PM
I can hear sound from all 5 speakers when i confic them but music comes out only from front. Spent 2 days googleing but no help. Any ideas ?
scarlet.ia Posts 17 Registration date Wednesday November 20, 2013 Status Member Last seen November 27, 2013 3
Nov 20, 2013 at 03:54 PM
1. the sound of the music/movie etc must be recorded in 5.1 and your sound system to be set correctly from Windows/Linux/Mac OS X.
2. if you have a sound system that knows "auxiliary" (see https://en.wikipedia.org/wiki/Aux-send it's enough to plug-in in your rear output and you'll hear in all speakers and sub-woofer (with this doesn't matter if it's recorded the sound in 5.1 system or it's radio stream that is normal)
Nov 11, 2016 at 12:45 PM
If that dosent resovle the issue if you have windows 10 downgrade to windows 7 and install all proper driver etc do updates or if you have windows 7 follow the same steps but just reinstall windows 7 trust me i know it works i downgradded to windows 7 and my speakers work fine :)
i think its a compatabile issue with windows 10 thing more than anything ive seen yet
