( HELP ) L-G Monitor says [ D-Sub Power Saving Mode ]
Ttheunluckyguy
Friday August 8, 2014
Aug 8, 2014 at 09:05 PM
Langlang - Feb 26, 2017 at 09:13 PM
- D sub no signal
- D sub power saving mode - Best answers
- D-sub no signal - Best answers
- Power saving mode in computer - Guide
- D sub power saving mode - Monitor Forum
- LG monitor says D-sub no signal ✓ - CPU & Desktop Forum
- Sceptre monitor no signal entering power save mode ✓ - Hardware Forum
- No signal power saving mode - Windows Forum
Ttheunluckyguy
4
Aug 9, 2014 at 07:31 PM
After 6 hours...I did it and nothing's worked.
Any other ideas besides removing the ram and graphics card??
Aug 10, 2014 at 12:52 AM
Does your motherboard have onboard VGA? Remove the graphic card and connect the D-Sub cable to the onboard VGA and check if you are able to get the display or not.
Also make sure that you have applied the thermal compound. Remove the old thermal compound from the CPU and from the heat sink --> Apply a little new thermal compound in the middle of the CPU and place the heat sink back properly.
