PROBLEM WITH WD 500GB EXTERNAL HARD-DRIVE
djseebee
Wednesday March 11, 2009
Mar 12, 2009 at 05:39 PM
djseebee Posts 2 Registration date Wednesday March 11, 2009 Status Member Last seen March 13, 2009 - Mar 13, 2009 at 11:06 AM
- PROBLEM WITH WD 500GB EXTERNAL HARD-DRIVE
- Wd drive unlock - Guide
- Hard drive regenerator - Download - Backup and recovery
- Working of hard disk with diagram - Guide
- How to install a second hard drive windows 11 - Guide
devis21
Saturday September 6, 2008
3
Mar 13, 2009 at 08:47 AM
hi,
you can attempt to fix the bad sectors by running a disk check.
this is happening because the HDD is problematic.
you can also try a "scanreg".
if even trying the HDD on another computer did the same thing, then your HDD is surely faulty.
remove your files from it as the HDD may die at any moment.
djseebee
thanks for replay devis1 .. acctuley onther parations are not showing at all and it gives me IS RAW but other one is showing is NTFS ... but now is become very slow of reading ... do u have any good software can recover to backup the data before it dead at all .... or there is any possible to recover partations or bad sector again .. i think its a logical bad sector not physical on ..... what do u think ?????
