Stuck in power saving mode!
Nickface21 - Jan 18, 2015 at 10:30 AM
xpcman Posts 19530 Registration date Wednesday October 8, 2008 Status Contributor Last seen June 15, 2019 - Jan 18, 2015 at 12:47 PM
So I was starting my computer, then it asked me to choose window 7 or window 7 ultimate. After I picked the computer just says D-SUB POWER SAVING MODE and shuts off. The same thing happend to me every time I try to use my computer. How do I somehow turn of this mode?
xpcman Posts 19530 Registration date Wednesday October 8, 2008 Status Contributor Last seen June 15, 2019 1,828
This message is given by the MONITOR when it's not receiving a signal from the computer. The failure is probably caused by a Windows software problem. Did you just restore the computer from a backup partition? If so, I suspect a failed hard disk.
