Suspected Malware infection: Monitor in Power Save mode.
BringMeTheAmity
Friday January 30, 2015
Jan 30, 2015 at 06:48 AM
BrianGreen Posts 1005 Registration date Saturday January 17, 2015 Status Moderator Last seen September 30, 2021 - Feb 2, 2015 at 04:03 AM
- Suspected Malware infection: Monitor in Power Save mode.
- Can jpg contain malware - Guide
- Redirect malware chrome - Guide
- Malwarebytes anti malware - Download - Antivirus
- Slendytubbies 3 infection calamity - Download - Horror
- Removing malware from chrome - Guide
BrianGreen
150
Jan 30, 2015 at 01:46 PM
Can you start your machine in Safe Mode? On Windows 7 machines repeatedly press the [F8] key immediately after powering on, and then choose "Safe Mode" (arrow keys and enter) from the menu that will appear.
If Safe mode works you should be able to run a scan from there.
Jan 30, 2015 at 08:50 PM
Jan 30, 2015 at 09:38 PM
However, to discount a software issue try removing all of the hard drives in your machine (if you do have more than one then make a note of which wires go to which drive). If it is a software issue, then powering on now will produce some writing on the screen similar to "No Bootable Device".
There is usually a splash screen telling you about the graphics card and how to boot to BIOS before an operating system starts anyway. Rarely do these go away so fast as to be not seen, but the process I described forces something to be displayed.
Good luck.
Jan 30, 2015 at 11:09 PM
I tried taking out my hard drive, but the screen goes into power save mode from the get-go. So it must be the hardware. Thanks for the help, I'll update this when I find out exactly what went wrong.
Feb 1, 2015 at 03:06 AM
