Laptop does not start, power LED blinks 3 times and stops.
milindgoswami
Tuesday February 17, 2015
Feb 17, 2015 at 11:14 PM
Maverick - Jan 6, 2022 at 05:53 PM
- Dell docking station power light flashes 3 times but won't turn on
- Lenovo power button blinks 3 times when plugged in - Best answers
- Lenovo orange light blinking 3 times - Best answers
- Acer aspire 3 keyboard light - Guide
- Hitman 3 cheats - Guide
- Psiphon 3 download - Download - VPN
- Monitor power light blinking but no display reasons ✓ - Hardware Forum
- Thinkpad power button flashes 3 times ✓ - Hardware Forum
Computertech
Friday February 6, 2015
892
Updated on May 22, 2020 at 03:13 AM
Please try the below mentioned steps and see if the problem resolves:
Do reply with results.
- 1. Connect the AC adapter to a known good power outlet. Check Power LED indicator on AC Adapter with/without plugging into the Notebook.
- 2. If LED on the AC Adapter goes off only after connecting to notebook, the issue is with the motherboard.
- 3. If the AC Adapter LED is ON, then remove external peripherals, battery, AC Adapter and press and hold the power button for 10-15 seconds to drain Flea power.
- 4. Plug in the AC Adapter and battery and check if the computer powers on.
Apr 20, 2015 at 01:40 AM
Jul 29, 2016 at 07:41 AM
I had the same problem with my Dell Inspiron 3537. I called customer care and they said that it's a motherboard problem and that I'll have to replace it. But this thing worked for me right now and I'm so relieved. I had two RAMs in my laptop. I opened the back of my laptop, tried checking the the RAM one by one. Then, I switched the places of RAMs and tried to turn my laptop on. After that, I put them back to their original positions. Somehow, it worked. My laptop started. Hope this helps.
Apr 1, 2019 at 10:02 AM
Dec 20, 2021 at 05:30 PM
The laptop shuts down immediately after boot screen. Charger is fine. It's spitting 20v.
Sounds like a CPU or motherboard issue. No beeps on boot either.
