No sound when using HDMI cable
Sarassi
Tuesday May 5, 2015
May 5, 2015 at 04:23 PM
Sarassi Posts 2 Registration date Tuesday May 5, 2015 Status Member Last seen May 6, 2015 - May 6, 2015 at 04:33 PM
- No sound when using HDMI cable
- Why is there no sound on my tv when connected to the laptop with hdmi windows 11 - Guide
- Hdmi sound driver - Download - Drivers
- Sound picker - Guide
Computertech
Friday February 6, 2015
892
May 6, 2015 at 08:46 AM
Hello Sarassi,
Please perform the below mentioned steps and check if this fixes the issue:
1. Right click the Volume icon in the bottom right side of the screen.
2. Select "Playback devices".
3. Check if you can see "HD audio" or similar options listed here.
4. If it is listed please make "HD audio" as the default audio device.
5. If it is not listed here, right click any empty space and check the option "Show disabled devices".
6. If the "HD Audio" is still not listed try updating the Video Card Drivers and then check again.
or
by going in to the sound options on my computer (which you can access in your control panel) then set your sound default as HDMI. This should solve the problem, just remember to set the default back to the laptops speakers when you are finished using it on your TV.
I hope that helps.
or
I hope that helps.
Sarassi
Tuesday May 5, 2015
I was able to use System Restore to end the issue. I'm not sure what happened in the first place, but I'm glad it's resolved. Thank you very much for your help!
sahni22
Tuesday May 5, 2015
May 6, 2015 at 08:43 AM
Check mic setting in ur laptop or computer or increase volume.of laptop to full.
