Cpu fan is running but no display on monitor
purushu - Jun 4, 2015 at 08:10 AM
xpcman Posts 19530 Registration date Wednesday October 8, 2008 Status Contributor Last seen June 15, 2019 - Jun 4, 2015 at 01:01 PM
hello friends,i got a problem
my cpu fan is running but no display on monitor.I also removed cmos & ram for 2 minutes and inserted back.after that,my cpu automatically turn on when the ups is on.....I have also check motherboard by removing ram( i heard a beep voice) I have got this problem after a lightining .please tell me a solution for this.....
xpcman Posts 19530 Registration date Wednesday October 8, 2008 Status Contributor Last seen June 15, 2019 1,826
I suspect you will need a new motherboard.
I suggest you have a local PC repair shop do a diagnostic evaluation since the PC needs "hands-on" access to find the problem.
