WIFI and WIFI Indicator light Won't Work [Closed]
Lola - Jun 19, 2015 at 10:30 PM - Latest reply: BrianGreen 950 Posts Saturday January 17, 2015Registration dateContributorStatus February 7, 2018 Last seen
- Jun 20, 2015 at 11:59 AM
Recently on my Toshiba Satellite Laptop, the WIFI indicator light turned off and won't turn on neither would it connect to the WIFI. I troubleshot it on the computer and it said it wouldn't turn on and is broken. Is it possible it is a hard drive problem? Or is there an easier way to fix it? Thanks.
BrianGreen 950 Posts Saturday January 17, 2015Registration dateContributorStatus February 7, 2018 Last seen - Jun 20, 2015 at 11:59 AM
Hi Lola,
Try a hard reset of your system ...
1) Remove the battery
2) Remove the charger
3) Push and hold the power button on for about 40 seconds - (it wont start as there is no power and you will look silly doing it, but do it anyway)
4) replace the battery
5) Switch it on like normal.
6) try the WiFI - if its not working now press the [F8] button.
Hopefully it will now be working and you might want to shower me in praise :^)
(if it doesnt work your not allowed to shower me in anything else!)
Let us know if this works.
I really appreciate thank you messages as a payment for solving issues :o)
