Flash drive problem (Location is moved or deleted)
Cha
Aug 12, 2015 at 12:19 AM
KY_WD Posts 2053 Registration date Thursday October 23, 2014 Status Member Last seen February 28, 2017 - Aug 12, 2015 at 10:09 AM
- Flash drive problem (Location is moved or deleted)
- Flash player download - Download - Other
- Wd drive unlock - Guide
- Postal address of my location - Guide
- Youtube location - Guide
KY_WD
122
Hello cha,
Please, follow these steps:
1. Open command prompt
2. Type the following:
attrib -s -h -r X: /*.* / s / d Then hit "Enter" and wait about 30 seconds
Be careful! Respect the spaces between words and script. Change the letter X with that has been assigned to the USB device on your PC (that you can see it in My Computer or Computer if it looks. It can be anything, depends on each computer.
3. Finally, browse the flash drive and delete the "RECYCLER" folder and if there is another one called "Autorun" you have to delete that too.
Hope this helps.
Hope this helps.
