Monitor goes into a power saving mode
stikey
Friday September 11, 2015
Sep 11, 2015 at 05:55 PM
stikey Posts 2 Registration date Friday September 11, 2015 Status Member Last seen September 12, 2015 - Sep 12, 2015 at 05:47 PM
- Monitor goes into a power saving mode
- Power saving mode in computer - Guide
- Lenovo monitor power saving mode ✓ - Monitor Forum
- D sub power saving mode ✓ - Monitor Forum
- Filezilla dark mode - Guide
- Sceptre monitor no signal entering power save mode - Windows 7 Forum
Look, you have said it yourself, shaking the cables makes it work. Hire a dog to wag his tail and then tie the monitor cable to it.
Seriously, it sounds like LOOSE connection. Either in the cable (you never specified if you move the monitor or the pc side) connected to the PC, or to the Monitor. Pull the cable. Does it come out? It is loose!
stikey
i don't think I would like to use your advice and to be honest I don't think it was very courteous i said I jiggle the cable and sometime it work and sometime it don't I don't think it is the cable
