Not turn on with battery but works!
nachaft
Monday April 6, 2009
Apr 7, 2009 at 02:30 AM
dumitriman - Dec 7, 2009 at 01:02 AM
- Not turn on with battery but works!
- Battery reset code - Guide
- Huawei battery reset code - Guide
- Airtag battery life - Guide
- Battery alarm windows 10 - Download - Diagnosis and monitoring
nachaft
4
Apr 8, 2009 at 12:03 AM
It works now!
I don't know exactly what happened but there is a touch pad above the keyboard for media access. I saw that these buttons are not working too, like the power switch in battery mode; So I tried to fix them and great the power switch works too!! What's the relation I don't know!!
veeking
Thursday March 19, 2009
Apr 7, 2009 at 07:58 AM
hi,
try to contact the dealer where you bought the pc.
this may be a problem in the internal circuit.
