TOSHIBA Satellite C50 "INTERMITTENT " Display Problem [Solved]
Ask a question jakerz86 - Last answered on Mar 7, 2016 at 03:13 AM by jakerz86
Can someone please help me with my issue? My Laptop has "intermittent" display problem. I say INTERMITTENT because the display does not always blank/black out. Here's the situation, whenever I turn on my Laptop all seems to be working fine except my display is blank/black. I tried the 30-60 seconds power thingy, but to no avail. But when I tried to turn it on and off then on then off you get the point, the display suddenly appears to be working. After using it for hours with no problem, I shut it down, traveled like 30 minutes from home to work. After arriving, I turned it on again and the display is blank/black again. And repeated the process until the display appears. What seems to be the problem? Can someone tell me?
Note: When I try to turn it on and off, I also close the monitor and open it. Also, if I shut it down in the office during break, turned it on again, my laptops seems to be working fine. It is whenever I travel, the symptoms appear not sure if it is due to shock/shaking.
Thanks,
+0
moins plus
Hello
Make sure your graphic card and graphic card slot is clean. Make sure your card is well seated.
jakerz86- Feb 15, 2016 at 03:57 PM
I don't think it is my Graphic card. Because I tried an external monitor and it is working fine.
Reply
Leave a comment
+0
moins plus
Have you checked your ram sticks?
jakerz86- Mar 7, 2016 at 03:13 AM
I have finally solved it temporarily... After I Open my laptop I have to tap it at the right side to make the screen image appear.
Reply
Leave a comment
Not a member yet?
