PC sound volume is low [Solved/Closed]
JuliaNell - Apr 17, 2009 at 03:46 AM - Latest reply: NipomitaMoitra 1 Posts Friday January 26, 2018Registration date January 26, 2018 Last seen
- Jan 26, 2018 at 02:51 AM
Hi there, I think I have a problem with my sound card, my PC volume is quite low and im sure it has nothing to do with the speakers because they are new. I checked my volume options and their on maximum. Is there a virus making my PC sound low?
DonQ 2 Posts Friday April 2, 2010Registration date April 2, 2010 Last seen - Apr 2, 2010 at 05:48 AM
+312
19
Yes,probably
In windows7 go to Sounds>goto Playback>
Pick speakers as output device
Goto Properties>At Levels check if is set at 100%>
Goto Enhancments>enable Loudness Equalisation>
Apply
Should be much louder now...
For little further enhancment ,
and If you have HD realtek soundmanager (R2.37) in your Control
try a equalizer setting like Classic
Hope this helped,
DonQ
You made my life much better :D
NipomitaMoitra 1 Posts Friday January 26, 2018Registration date January 26, 2018 Last seen - Jan 26, 2018 at 02:51 AM
Thank You so much.You saved my exams!!! :D
ibn Alhazred - Jul 20, 2010 at 03:26 PM
+30
My computer suddenly got this low sound -problem and I tried literally everything to bring the sound levels back to normal. Then I noticed that (for some very mystic and strange reason) the sound levels were normal if I plugged my speakers in the front jack of the computer and something in the rear jack. Now I keep broken headphones in the rear jack to keep the problem away. Strange, but it works for me.
+25
I have the same problem.. I used the same drivers,, even I download the sound driver in the manufacturers website, one thing I observe when I install windows xp volume is much higher than windows 7.
i tried 2 laptops acer aspire a one, Windows XP & windows 7 installed and iwas correct volume I higher than windows 7..
Anyone knows how to resolve this case?
+11
hi..would u help in solving my problem..my pc is semens fujutsu..the sound is low when I play something but it does well when I use the headset.
thank u
+11
Thats dude... wonderful!!
yea Front jacks works while rear doesnt.. peculiar though..!
+10
Just reinstall the sound drivers with the cd...
We have the same problem, whats the name of the cd do you need to use?
i too have the same problem in ma leaptop after windows 7 was installed.. what to do??
andygrt.cz 9 Posts Monday September 22, 2008Registration date May 11, 2009 Last seen - Apr 17, 2009 at 07:27 AM
+4
hi,
right-click on the small speaker in the taskbar and select Adjust Audio Properties.
under the Volume tab, click on Advance.
there, you will find a lot of volume controls
