Power saving mode and the keyboards or mouse won't turn on [Solved]
Ask a question Abel - Last answered on May 22, 2016 at 10:44 PM by Abel
I have a dimension E521 and each time I turn it on it says power saving mode and the keyboards or mouse won't turn on I need
-1
plus moins
Either the power supply has failed or the motherboard has failed. The monitor is in "power save" mode because it's not receiving a video signal. I suggest you have a local PC repair shop diagnose the problem.
Abel- May 22, 2016 at 10:44 PM
OK thank you very much man
Reply
Leave a comment
Not a member yet?
