Monitor: No signal 'Entering power saving mode shortly'
noor1365
Friday December 9, 2016
Dec 9, 2016 at 03:19 AM
KY_WD Posts 2053 Registration date Thursday October 23, 2014 Status Member Last seen February 28, 2017 - Dec 9, 2016 at 10:59 AM
- D sub no signal
- D-sub no signal - Best answers
- Lg monitor no signal entering power saving mode - Best answers
- Monitor power light blinking but no display reasons ✓ - Hardware Forum
- Monitor zoomed in - Guide
KY_WD
122
Hello noor1365,
Welcome to the forum! I have a couple of questions regarding the issue that you have. Have you bought the new PC already assembled or it came by parts and you made it? I'm asking this because there could be any incompatibility with any of your parts preventing you to boot normally your machine. Have you checked that?
If you did, then revise the power outlet of the wall where you connect the computer, because it might not give enough power to the PC.
Also, if you have another monitor to try with, connect it to your computer and check if you will get any signal.
Good luck! Have a great weekend.
