Laptop power on, no display, no led light, no hdd led.cpu fan on.
Sunash1994 Posts 3 Registration date Sunday May 31, 2020 Status Member Last seen June 2, 2020 - Updated on Jun 2, 2020 at 02:40 AM
Sunash1994 Posts 3 Registration date Sunday May 31, 2020 Status Member Last seen June 2, 2020 - Jun 2, 2020 at 03:21 AM
Sir,My laptop is power on but no display,cpu fan running.hdd led not blinking, keyboard light not blinking.what reason sir.Plz tell me.
David Webb Posts 3177 Registration date Monday November 25, 2019 Status Administrator Last seen May 15, 2023   6,925
Jun 2, 2020 at 02:43 AM
If the fan is spinning when you switch on the laptop and there's no display, this can be a problem with the memory. Try removing it, putting it back and also if you have 2 memory cards try with only one (alternating between RAM slots to establish if one is faulty).
You can also try this:
Remove battery, unplug power, hold power button for 60 seconds, turn on computer with power plug only, then shutdown, add battery and restart
Regards
David Webb
Content Editor and Community Manager - CCM.net
I tried sir .but not working.... Is there a problem graphic video chipset
