HP Compac Presario Laptop won't turn on...jack led light 5 secon [Closed]
Friday January 18, 2013
My HP Compac Presario will not come on.
I connect AC power without battery on it, and the led light on ac jack, only stay for 5 seconds on it, then came off again...
A try 10-30 on power botton, but nothing...
Only connect the AC power, and the led on jack connector switch on for 5 seconds only, onlye the jack led light...then came off again...
What can i do to trun th laptop on again...? please help...please...
I only work with the laptop on it AC power...without battery...
Ac power is ok by the way...it works fine...
This problem only cames, one of thsi days, i simply connect the ac to the power line, and then a connect the jack ac power to the laptop, from them moment, the laptop, no more switch on again...
I normaly connect the ac jack to laptop, first, and then a connect the ac to the power line, and push the power botton...and all works fine...
until that day, e just did the reverse way...only that...and no more switch on...only the led light ner to ac laptop jack, switch for 5 seconds, then came off softly...
Help
Plase help...
Regards
Subscribe To Our Newsletter!
The Best of CCM in Your Inbox
